Re: button for cutomized model view?
@surfactant,
If you use visual basic to compile the journal into a dll then the time lag will go away. As I am not well versed on what you need to do to set up the visual basic environment you'll need to look at the programming forum for help.
So once you have a dll you can point the button's action to the dll instead of the original journal vb file.
Abe
You'll need an NX API author license to compile your journal code to a dll file.
Hi @Abeinjapan   Thanks for info on compiling dll!
Hi @cowski1   Thanks for your advice!
 As an alternative to the journal, I'd suggest orienting the view the way you like and saving it. You can quickly change back to your saved view and orientation by double clicking it in the "model views" shown in the part naviator.
Generally in my daily work, the node "Model Views" in the part navigator is folded to leave maximum space for "Model History". To frequently unfold the node and find the custom view seems not to be very practical.
I'm not sure whether we have this license. Macro seems to be good enough for the simple job. Let me have a study of the official documentation first and try to solve the pop-up error message.
