cad module
Dear every body,
How do we know some feature are running in specific module?
for example: if we need feature refit face , how do we find it on the specific modul?
Thank you in advance
Dadang
3 REPLIES 3
Re: cad module
You can try the command and then look at the log file to see if it recorded a module license change???
Re: cad module
I will second Ryan reply. In addition you can use LMTools utility for the same.LMTools.jpgBest Regards
Kapil
Re: cad module
Dear Kapil,
Thank you for your reply, it looks true
Best Regards,
Dadang
