cannot select previously selected face by using edit parameter or edit with rollback command
Re: cannot select previously selected face by using edit parameter or edit with rollback command
What feature type were you attempting to edit/rollback?
Had you deselected the original face - and that's when you were unable to select it?
What was your Selection Filter set to?  Was it perhaps set to something other than "No Selection Filter", or "Face"?
The more detailed information you give us, the better we can assist you.
Regards, Ben
NX (v17 - 1872) | Teamcenter (9 - 12)
