centerline in view break
hello,
everytime I create a view break with a 2D or 3D centerline in it, the centerline dissapears at each update.
If I uncheck the view break in the part navigator, I can see it, but when I reactivate the view break, it dissapears again.
So everytime I update my view, I have to create another 3D centerline and re-attach the dimensions.
Solution anyone??
Thank you for your reply
Eric Ferland
NX12 user
Re: centerline in view break
Use Broken (Legacy) I believe View Break is fixed in NX11.
Support for maintaining the display of centerlines in a view when a view break is applied was addressed in NX 11. You indicated you're using NX 10; depending on your specific use case, one option might be to add your centerline using Expand view.
It works, thanks!!!
Eric Ferland
NX12 user
