centerline question
Hello
how can I have a centerline between 2 lines, I made BEAD's so I need to annotate the centerline of those BEAD's
Re: centerline question
Use '2D Centerline' command.
Ganesh
oke thanks,
i need also a centerline between this (see picture)
okey just use 3D-centerline and use extension = 0.0000
so I solved it myself
