circular pattern error
When I try to edit an component circullar pattern, I get the following error message:
"pattern master is unloaded"
I tried loading all components fully, and the error message still appears!
Thank you for your reply
Eric Ferland
NX12 user
Re: circular pattern error
Hi @EricFerland ,
Could please reproduce it on simple part / is it part specific? Also if possible, share an image.
It seems to me an issue and should be reported but this might have fixed in later NX versions. So if you could share additional information, I can chek it in NX12 or NX1847.
Samadhan
GTAC | NX Help: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
