copy a slot in a diferrent position. (NX12)
Builder
Builder
Somebody knows what command can I use to make a copy of an inclined slot and position it perpendicular to an axis?
Have a look to the file I attach.
Jose Carlos
4 REPLIES 4
Re: copy a slot in a diferrent position. (NX12)
Hi @JCP ,
Pattern Face is one of the option.
(view in My Videos)
Samadhan
GTAC | NX Help: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
Hi @JCP
I would suggest using pattern curve with general layout (CSYS to CSYS) or synchronous copy/past face.
Hi @JCP ,
Try 'Clock' option from pattern feature. User can select individual instance point from pattern and clock respective instance (angle, distance etc.)
Amol
Builder
Builder
Hi
Thanks to all. This option is the best!!
Jose C
