creating assembly with parts from library
Hi everyone,
when I try to add some parts from library I can not do it because some errors appears:
Do you have any idea why it happened like this?
best regards
3 REPLIES 3
Re: creating assembly with parts from library
What load option have you set in The Assembly Load Options? Is it set to some specific search directory?
Best Regards
Kapil
I try to change this options few time but it didn't help ;(
Restart your NX session, create a temporary assembly file and add the same Reusable Component to it. Save the files and close the parts. Now open your original assembly and see if you can add the Reusable Component.
