creating multiple associative points
hello eveyone,
I want to create multiple associative points based on the coordinates in an Excel File. I want to be able to change these coordinates by Excel any time. How can I do this?
Re: creating multiple associative points
Reuse Feature with multiple associative csys or a sketch containing points and constrained somehow will give you that functionality.
Or simply a Sketch with points (constrained to x, y, z) and you can simply import the expressions from spreadsheet.
you can use UG_cell_Read in the expressions.
Make for every point a X,Y,Z expression and link the to a cell
after changing the excel use the "update for external Change" to update the part file.
only if it are a lot of points it can take some time
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Using a sketch in this instance assumes that all the points lie in the same plane...
Thank you all for solutions but there are more than a 100 points on the same plane. Is there a faster way to do this? I’ve already tried the approaches commented above
Thank you for your replies. I figuredi it out . Video in the attachment
(view in My Videos)
Great solution,
Taylor Anderson
NX Product Manager, Knowledge Reuse and NX Design
Tel: +1 (602) 441-0683
taylor.anderson@siemens.com
