curve projection
Solution Partner Innovator Solution Partner Innovator
Hi
I want the curves to be projected onto the bottom surface.
I would like to be projected in the following way
What is a possible function?
3 REPLIES 3
Re: curve projection
did you try the flattening and forming feature?
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Try 'Wrap/Unwrap Curve' command.
Whatever it is, I think you are tiring to kill the system performance.
Find the smallest unit and then try to use Pattern functions and mirror functions to propagate it around.
Michael Fernando
Die Designer
NX 11.0.2.7 + PDW
