customise NX material library
Can anyone reply, how to customize the material library as per customer requirement in NX9.
Note that, we would like to add only the below properties,
material :- for eg, STL-10
density :- 7.85e-06
We require only the above listed parameters, which we are using to assign for solid models. We have around 25 to 30 variety of materials. Please let me know how can we add these things to customer defaults.
Yunus
Re: customise NX material library
there is a video at the top of the page you might find worth referencing
Kapil
Thank you very much.
Yunus
