decrease of efficiency NX 6, 7.5, 10 - It makes simple extrude in 10 minutes!
Hi, I have problem with NX 6, 7.5 and 10. When I try to insert block or make simple extrude it started to thinking a lot and inserting block   takes 10 minutes ! I use Windows 10 if it make diference. muli_NX10.png
Re: decrease of efficiency NX 6, 7.5, 10 - It makes simple extrude in 10 minutes!
It really shouldn't take 10 minutes.  Have a look at other things that may be impacting the performance:
- License server availablity
- Windows update
- Some other application?
Here's my system running NX10 inserting a block (although it is Windows 7):
(view in My Videos)
take a look at your processes and see what's going on. While I have not had any slow downs with NX, a few other Softwares that I run are pretty sensitive to virus scanner activity.
When running certain things, I see a flurry of processes going off that was tied to TrendMicro and I had to have the IT peoples make some tweaks.
Rob Newcomb, CAD/CNC/Simulation manager
Elmhirst Industries, Specializing in Prototype sheet metal stampings and assemblies
Production: NX 12.0.1 / Autoform r7 /WorkNC 2018 r2
Testing:nothing.
PC: Rave Cadbeast: Intel(R) i7-4790K CPU @ 4.GHz /32gb ram /NVIDIA Quadro P2000 on Win10 Pro
