define weld standard
Hello
I would like to predefine some standard of displaying Auto Weld Symbols.
For example, I`m sending images. Lower symbol is created using Auto Weld Symbol, but I would like to show this symbol as upper symbol. Where can I predefined it?
In NX training materials I found, there are some customer defaults, with preferences>
Common
Creation
Custom Weld Points
Drafting
I cannot find section DRAFTING. From this material, this should be the place, where I can set this standard.
I`m on NX9
