deformable parts - range number
is it normal that when I create a deformable part with the option "range number" I can only use the slider to select a value. I would like to enter a precise number, but also need the range to limit the value I can enter.
Thank you for your reply
Eric Ferland
NX12 user
Re: deformable parts - range number
Hi @EricFerland,
in the input box, enter the value and press the 'Enter' button in the keyboard.
Thank you...
Using NX11 and NX1847 serie
RuleDesigner PDM
Hi @EricFerland,
For both options, 'By Whole Number Range' and 'By Number Range', there will be slider as well as input box where you can enter the value you want to use.
Ganesh Kadole
I tried that of course, but it keeps the value selected by the slider, manuel input with keyboard does not work
Eric Ferland
NX12 user
Hi @EricFerland,
have you write a value that is between the range and the value is a number acceptable from the setting used to create deformable part ? For example 11.2 need the correct option.
Thank you...
RuleDesigner PDM
yes of course
Eric Ferland
NX12 user
Please attach the file and which dimension want to create.
Thank you...
RuleDesigner PDM
I get this error message when attaching my file
"The contents of the attachment doesn't match its file type."
Eric Ferland
NX12 user
Hi @EricFerland,
you need to zip the file.
Thank you...
RuleDesigner PDM
Try zipping the part file before uploading it. Ironically, this site won't let you upload .prt files. Smiley Frustrated
