Re: deformable parts - range number
Here's the file, the expression is "ID" and the range I need is 3.500 to 4.999"
I have this problems with other files too.
Thank you for your reply
Eric Ferland
NX10 user
Hi @EricFerland,
I don't have problem to change value from the min to the max.
Please verify to be to the last Maintenance Release and relative Maintenance Pack of NX 10.
Thank you...
Using NX11 and NX1847
RuleDesigner PDM
Thank you very much for your time, it is greatly appreciated.
Our system (and  defaults) are controlled by another division of our company, so there is nothing much I can do, except raise the problem to them.
Do you know if there is a special setting or default for that?
Eric Ferland
NX10 user
Hi @EricFerland,
There is no special setting for it. Whatever options are available are within that particular dialog.
I had used part provided by you and able to redefine the deformable part without any problem (value range along with a box to enter a user defined value) by using NX 10.0.3.5 MP18.
Ganesh
Hi All,
I just found the problem; after hitting enter twice, it works...
Eric Ferland
NX10 user
