design constraint (topology)
Hello ,
i can't delete these settings,
for each component the Constraints are simply set to "overhang prevention"
and I can't delete this... ok i can delete it but when i go back into the program it will be set again without doing anything...
can someone help me?
regards,
LB
4 REPLIES 4
Re: design constraint (topology)
Use the Dialog Reset and this will fix the problem.
Guy
Guy Wills
@GuyWills
thank´s now it works  Smiley Happy
do you know why it does this, or is it just a bug?D
LB
This is a common occasional bug across NX.
Guy Wills
The general "rule-of-thumb" is that if a dialog does not appear to be behaving correctly; values reappearing, buttons still grayed out, odd results, etc, try hitting the reset icon. If you find that this is a persistent, repeatable problem, by all means report the issue to GTAC, though it would help to not reset the dialog before you call them as they will need a copy of your dialog memory file.
Cheers, Ben
