dimension drafting
how it is possible to manage the line length (below). I'm not find the parameters in customers default.
Emmanuel
Re: dimension drafting
you can find the setting in the Drafting Standard -> Annotation -> Line/Arrow (register) -> Dimension Arrow Out Length Factor
regards André
Hello André,
I have also testing this parameter without succes. You are not in NX10?
Thanks.
Emmanuel.
My picture is from NX 9. But I've tested it in NX 10 (NX 10.0.3.5 MP6) too. And it works:
But I created a new part. Maybe it doesn't work with existing parts directly. Try to Load the changed Drafting Standard:
Hello André,
it is well this parameter. but it is not possible to change a dimension already performed.
Thanks.
You're right. The Setting works only for new dimensions. Even an inherit doesn't work.
Regards André
