dragging handle not appear in multi-view layout
I often adjust Curve Length by dragging. But sometimes in a multi-view layout, the dragging handle (purple one below) never appears in the work view, no matter where the mouse cursor is put. It does appear in those non-work views always.
The issue does not occur all the time, but very often.
Any clues on fixing it would be appreciated!
Re: dragging handle not appear in multi-view layout
Some findings:
In a multi-view layout, if view A has high zoom level and view B has low zoom level, the moving handle might be pushed far outside and unable to be seen in view A.
But if the layout has more than 2 views, the behavior seems to be difficult to predict. I think it could be improved.
