dwg_solid_file
Builder
Builder
Hello guys,
i attached dwg file
actually its solid file but
in NX shown like sheet / surface or etc
i wanna work in file but no faces i can select !!!!!!!!!!
have anybody idea to make it solid!!!!!!!!!!
and when i call it in nx its not shown in environment display.
Warm Regards
Thomas Roman
Machine Designer
Re: dwg_solid_file
Right click in the graphics display and choose "Replace View > Custom Views". Choose "#Active1" and you'll see your geometry.
Regards, Ben
Re: dwg_solid_file
Builder
Builder
Hello@BenBroad
you are right dude, accepted
but what about model
how can i make it solid
have any idea!!!!!!!!!!!!!!!!!!!!
Warm Regards
Thomas Roman
Machine Designer
Re: dwg_solid_file
Are you using File > Open, or File > Import?
I used File > Open and it was converted to a solid body for me.
Re: dwg_solid_file
Builder
Builder
Hello@BenBroad
you are right dude!!!!!!! Accepted
but now how can i make it solid
have any idea!!!!!!!!!1
Warm Regards
Thomas Roman
Machine Designer
Re: dwg_solid_file
Builder
Builder
hello@Benbroad
Using direct through open>dwg
Warm Regards
Thomas Roman
Machine Designer
Re: dwg_solid_file
Builder
Builder
Hello@Benbroad,
Thanks for help man
I used>new>Import>dwg for me
thanks for help man
Warm Regards
Thomas Roman
Machine Designer
