edit drafting standard´s default location
Hi guys,
Does anyone knows if its possible to edit drafting standard´s default´s location? (path)
My problem is I have a user wich contains an Ñ on its name, so NX does not aloud her to "save" or "save as" any drafting standard, because it tries to do it in:
C:\Users\<username>\AppData\Local\Siemens\<NX version>
As username contains ñ I think NX is not able to reach default folder.
So as I think change user name is not possible righ tnow, is it possible to change dafault location for nx to save thoose?
I know about UGII_LOCAL_USER_DEFAULTS variable, it alouds me to change where NX "reads" dpv, but It didnt help with "default location for drafting  sandards.
Thanks in advance.
Re: edit drafting standard´s default location
Have you tried setting these:
# Drafting Standards
UGII_DRAFTING_STANDARD_DIR=
UGII_LOCAL_USER_DRAFTING_STANDARD_DIR=
-Dave
That was it! thanks Dave!
