environment variable for Imageware Integration
By chance, does anyone know the environment variable for Imageware integration in NX10?
The online documentation states that UGII_IMAGEWARE_EXEC has to be properly defined but it does not state what it should be set to.
https://docs.plm.automation.siemens.com/tdoc/nx/10.0.3/nx_help/#uid:index_modeling:xid869229:imagewa...
I am guessing that you need to add something in ugii_env.dat along the lines of
UGII_IMAGEWARE_EXEC =TRUE # or 0
 Interesting side note, I met someone who has the old Imageware floppy disks. They told me the software still works great.
Re: environment variable for Imageware Integration
Point it to the path of the imageware executable file (include the filename).
For example:
UGII_IMAGEWARE_EXEC=C:\your_path\imageware.exe
Regards, Ben
Thanks, I do not have the original imageware software but I am going to look for a copy
Siemens Legend Siemens Legend
Siemens Legend
you, need both the software and a license file....
