error is export or model copy.
Solution Partner Innovator Solution Partner Innovator
Hi.
The error is activated when opening FILE.
I try Export parasolid. Then the object is not selected.
and try copy to object.
The following errors are activated.
I want to Export parasolid. Is there a solution?
