extend a surface by moving its edges
I just learnt that in NX Enlarge can extend or shrink a B-surface by moving its edges.
Alias has a command Extend doing the job. I learnt from a tutorial that the Entend command has some handles for adjusting the edge in a more flexible way (as shown below).
Is this possible in NX? Thanks!
3 REPLIES 3
Re: extend a surface by moving its edges
Not exactly what you are looking for (i personally use Untrim to get the original patch and then do the modifications)
but still if you find it worth ...X-Form has lot of controls...below i am showing proportional (linear extend....just drag the first pole and the rest will follow a linear pattern...the last one will have no movement at all)
proportional.jpgBest Regards
Kapil
Hi @kapilsharma  X-Form does the job! And also thank you for sharing your practice!
I just realize that X-Form > Proportional would change the shape of the main body of the surface to be "extended".
Alias' Extend seems to do some refitting work in the "extending" process to achieve certain combined result of both "Enlarge" and "Snip" in NX.
GUID-74697DAB-33CC-4510-88A8-AF1496E06414.pngAlias' Extend with 3 manipulators for "skewed" enlargement
Any suggestions on how to do it in NX would be appreciated!
