extrude from face edge fail
NX 12 Extrude from surface edge gives convergent body or solid convergent body,
How can I turnoff this option?
Sorry for bad english.
11 REPLIES 11
Re: extrude from face edge fail
normally it's creating a normal solid or sheet body.
Is the base part already a convergent body?
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Base part is solid body.  IS there way to convert convergent body back to sheet body?
I have attached part file
Thank you
can you send also the part?
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Ok. I upload to this link https://files.fm/u/tgm8yeq9#_
When u use the bottom face (region boundary selection) i don't get a Convergent body.
When using the top edges of the pocket i get a convergent body.
If you prefrom a Optimize face on the base body and then create a extrude from the top edges. it works fine.
(view in My Videos)
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
@sukku
Hi there, I came across this problem a while ago!
The issue lies within a new functionality of NX12.
If you go into preference / modeling you will come across an option to specify what to do with 1deg spline.
You should look into that see if it solve this issue but i'm pretty sure it will!
Have a good day!
Thank you
This worked fine
As you mentioned  extrude from liner line often gives convergent body.
I have located that settings but it's cant be canceled
Can you show how to uncheck it
Thank you very much
Hum... I honestly don't know... my computer is dead so right now i don't have acces to NX.
Maybe you can change this setting from the costumer default.
