Re: extrude from face edge fail
Does anyone know if there is a customer default to have "Treat Degree 1 Spline as Polyline" unchecked as a default? Otherwise it turns back on every time you open up NX.
Thanks in advance!
@FBergeron wrote:
@sukku
Hi there, I came across this problem a while ago!
The issue lies within a new functionality of NX12.
If you go into preference / modeling you will come across an option to specify what to do with 1deg spline.
You should look into that see if it solve this issue but i'm pretty sure it will!
Have a good day!
FYI, GTAC says this will be a customer default in 12.0.2  Mid July
Rob Newcomb, CAD/CNC/Simulation manager
Elmhirst Industries, Specializing in Prototype sheet metal stampings and assemblies
Production: NX 12.0.2 / Autoform r8 /WorkNC 2019 r1
Testing:NX 1855
PC: Rave Cadbeast: Intel(R) i7-4790K CPU @ 4.GHz /32gb ram /NVIDIA Quadro P2000 on Win10 Pro
