fail to draft a face
Hope to have your suggestions. Thanks!
Re: fail to draft a face
Hi
you first need to sew the faces.
Meinolf, , Leistritz Turbinentechnik GmbH
Production: NX10.0.3, TC 10.1.4
Testing:NX11 Beta
Hi @Triumphator   Thanks for the solution!
Alternately, use the "edge" type of draft and select the edge that you want to hold constant. This will allow you to add draft to the sheet body without sewing them first.
Hi @cowski1   Great altenative approach. Thanks!
