fail to set G2 to an intersection spline
Hope to have a workground. Thanks!
4 REPLIES 4
Re: fail to set G2 to an intersection spline
you can use one more point in the spline. Works for me at least.
Hi @kapilsharma  I don't know what you did it exactly. It does not work for me. Thanks!
Hi surfactant,
Sorry yes i now realize it is not working in the same sketch where you have taken the intersection (i tried to set the intersection curve degree to quintic also and that too didn't help) so in the end i used a second sketch and then it worked fine.
Attaching the part herewith.
Best Regards
Kapil
Hi @kapilsharma, Thanks a lot for the solution!
In other words, the intersection curve need to be created on a single plane outside the sketch. The situation is similar to a previous one as described by @TimF.
