file path in drawing table in NX
there is any possibility to display path to the curent file in drawing table in draft in NX.
I know there is possibility to to that in Solidedge by attribute %{file name (full file path)}.
It is possible in NX? Are you able to recomend me some round around?
best regards
Lukasz
Re: file path in drawing table in NX
Hi @lukipap ,
1. Create below expression in modeling.
filepath=first(mqc_askAssemblyStructure())
2. And add above expression in table cell using Edit Text.
Above expression will give you path + part name. To get just path, use below formula for expression -
subString(first(mqc_askAssemblyStructure()),0,Length(first(mqc_askAssemblyStructure()))-Length(ug_askCurrentWorkPart())-1)
(view in My Videos)
Samadhan
GTAC | NX Help: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
Thank you man! It is exactly what I need Smiley Happy
