how to break a linked exterior
Hi all,
Is there a way to break the Linked Exterior?
I know that it can be done by the relationship browser of the WAVE module.
Butt is there also another way?
greats
Ruud
4 REPLIES 4
Re: how to break a linked exterior
Hi Ruud,
I guess you can always suppress/delete the linked exterior feature from the part navigator of the main assembly (where you created the linked exterior)
Kapil Sharma
Dear Kapil,
it's not that we want to delete or suppres the linked exterior.
Whe want to have it still in the tree. butt not that it updates any more.
Ok..sorry i misunderstood your question then. Can you try using EDIT/FEATURE/REMOVE PARAMETERS on the linked exterior objects. It will turn them in dumb bodies.
Best Regards
Kapil
I have tried the edit feature, butt here is no option to break te link.
Remove Parameters can work.
It's creates single bodies of the linked exterior.
this can work.
thanks
