import picture
Does any one know how to import picture by using Tiff, jpeg file to ideas?
thanks in advance
regards,
dadang
Re: import picture
There is a command Raster Image that will do this. Will need Studio license to work.
Steve V
Re: import picture
This method works great!
https://vimeo.com/83654051
Re: import picture
You can do it without a studio license now, at least in NX10.
Just type raster image in the command finder to locate it, then if you have help setup, you can hit F1 as to how to use it
I've brought in a logo, put some lines on it using a compination splines and sketches
Rob Newcomb, CAD/CNC/Simulation manager
Elmhirst Industries, Specializing in Prototype sheet metal stampings and assemblies
Production: NX 11.0.2.7 / Autoform r7 /WorkNC 2017 r2
Testing:NX12 EAP
PC: Rave Cadbeast: Intel(R) i7-4790K CPU @ 4.GHz /32gb ram /NVIDIA Quadro K2200 on Win10 Pro
Re: import picture
Siemens Legend Siemens Legend
Siemens Legend
There has been a licensing change, you no longer need the Studio Visualize to display raster images.
 I think that the change was in NX10
 Tomas
Re: import picture
cowski1 3rd Gear
3rd Gear
The change happened in NX9, FWIW...
