inherit assigned feature color for hidden lines in drafting
Hi, is it possible to inherit for Drafting hidden lines the color assigned to specific faces of the model?
assign fc.JPGThat is: I have assigned a color to hole faces (with Assign Feature color or CTRL J), I would like to see them in the same color in Drafting views hidden lines. See photo below and file
Thankyou
Re: inherit assigned feature color for hidden lines in drafting
I have found the solution by myself, and I share it in case someone is interested.
There is an option to flag in Preference-Drafting- View-Common-Configuration: In the Setting choose Wireframe Color Source: From Face
