little help for this shape using synchronous feature.
Hi guys,
i have a little problem with this simple CAD model which i got from our designer. i just need to re-size and make little adjustments on the radius of the sphere and  corner R  face.because it has a blends i cant modify unless i have to delete all blends and change the radius value of the face and sphere, and then remake the blends again.l which is quite time consuming.
do have suggestion how to do it easily using synchronous modeling?
the green colored face is the one i want ro modify.
thanks guys!
Re: little help for this shape using synchronous feature.
To me it looks like deleting the blends is inevitable and reblending will certainly give you a more clean result.
However it is difficult to comment on it without having the model. Can you share it?
Best Regards
Kapil
that is always been my problem for CAD models with blends.sometimes is easy to delete and reblending but there are also some cases that it is very difficult to reblend it esp. if its a very small CAD solid. it takes time for me to think and solve this kind of issue most of the time.
thanks for the response.
here is the CAD model
I didn't get much time to com plete the part but i am attaching one part file herewith (with the bif spherical surface radius control (right now i have made it 2).
This part file is in NX10.
Best Regards
Kapil
thank for the quick reply.
at the moment i am using NX 8. but i am waiting for the new installation software for NX 10 that will arrive soon. for now i cant open this file. so sad.
so sorry...i don't have access to NX8 as of now so cannot be of much help.
Best Regards
Kapil
hello kapil,
i have nx10 already.
how can i open that file? ...
sorry for the delay i did have problems with the installation of the license in the couple of days.
thank you kapil, its a zip file. Smiley Happy
im still new at nx 10 but i will try to do the same thing in nx8 if this method works more easy and fast.
