make Rib displays in drafting as non sectionable
is there any way to make no sectionable ribs, in drafing I mean.
we can, make no sectionable components, but I found myself trying to display ribs non been sectionables (because as standard, these shoudnt be sectioned).
any advice?
thanks in advance
11 REPLIES 11
Re: make Rib displays in drafting as non sectionable
While creating the base view, select the object as Non-Sectioned.section.png
Hi @mnr76,
it's not possible. There is an ER open.
@GaneshKadole, the question is other.
Thank you...
Using NX1859
RuleDesigner PDM
@Ganesh_Kadole, the question is other.
@cubalibre00: My bad. Thanks for the correction and ER information!
Existing ER 1813756: Can't Exclude a rib or feature from section view crosshatch.
Regards, Ben
not for the solid itself, but part of it, as ribs.
thanks!
thanks! will have to wait then. wanted to be sure it was not posible.
thanks ben!
In the mean time you can use a workaround (sorry i know the example is based on quite simplistic model and this method will not work accurately for other shapes than just flat surfaces) but still..
In the past we used this technique a bit as a workaround (especially for ribs smaller in size compared to the overall model). We just circumvented around the rib portion slightly.
Best Regards
Kapil
