mirror assembly
Builder
Builder
hello experts,,
as we know the fabulous command in NX that assembly mirror
but today i have query in that,
what is diffrent bet^n accociate & non accociate mirror
i used both of it,,,,
but my application like that if i mirror some part /assembly,,& will it modify in future ,,,mirror part should be also modifiy automatically,,,is there any option to do that ,,,,
i cant do this right now,,,where i am wrong i cant understand
is there any solution for that guys
thanks
Warm Regards
Thomas Roman
Machine Designer
7 REPLIES 7
Re: mirror assembly
I think when mirrored the parts created are "wavelinked" to the original so if you modify the original they also modify (simetrically). You cant create a mirrored assembly where the position is associated, if you move one part that have possitioned mirrored (same part) it wont update
Re: mirror assembly
big limitation is that mirror assembly is not associative. All others CAD have mirror assembly associative, but NX 11 on 2017 no.
Thank you...
Re: mirror assembly
Follow below link to create mirror linked part forhttps://docs.plm.automation.siemens.com/tdoc/nx/11/nx_help/#uid:xid1128417:index_assemblies:interpart_modeling:wave_topics:xid384602:xid384603
Re: mirror assembly
Hi @Thomas_Roman,
What is your intent?
Re: mirror assembly
Builder
Builder
hello@Ganesh_Kadole
actually i wanna mirrorr assembly which should be update if i updare that part/aasembly  in future,,currently i mirror some part,,& modify that parent part the mirror part cant be modified automatically,,,my application is that ,,if i modify part (parent part )after mirrored in future anytime,,,,,should be mirror part automatically change
thanks
Warm Regards
Thomas Roman
Machine Designer
Re: mirror assembly
Well if I update the position of the parent component in the assembly then it gets updated for the mirrored component also (created using the asseociative option). Same if I update the part/component geometry. Could you please share some snaps or assembly part files.
Re: mirror assembly
Builder
Builder
hello@Ganesh_kadole
for eg.see in this screenshot i attached it ,,in assembly i mirrored both side shaft ,,,but in that ,,,after editing of shaft,,, assembly not updated,,even i used accosiative mirror assembly,,,
assembly mirror part.JPGmirrored end shaft both side
Warm Regards
Thomas Roman
Machine Designer
