named expression type- change
Hello all,
I had come across a situation where I had created a named expression with type length(mm unit), which was supposed to be constant type.
Created dimenion then used in several sketches and several times.
Finally I realised the mistake and wanted to change. When I get in to expression list it didnot allow me to change the expression type untill I changed all references to other expression.
is this how it intent to work ? or am I missing something here?
help me on this !!!!!!!!!!!!
thanks in advance..
NX10.0
Re: named expression type- change
Hi @sathya,
That's correct. You can not change dimension type of a expression if you have used/referenced it already.
Ganesh
Good to know @GaneshKadole.
thanks ...Smiley Happy
