need NX drawing lines all black
Builder
Builder
How can I make a drawing in NX that have everything black and white, no other color?
For example, I add a section view, it is brown. ordination dimention are blue. Line are blue. please see pic.
Is there settings/preference I can change to make everything black, no color. 1233333333333333.png
Re: need NX drawing lines all black
From drafting, in the Part Navigator window, RMB on Drawing > uncheck Monochrome.
The easy way is to right click on your drawing in the part navigator and choose the "monochrome" option.
Builder
Builder
thank you. it works and looks good
In addition if you want it white on black go to preferences -> visualization performance to set the colors.
Scott
