newbe to NX setting defaults
I'm new to NX (just a few days) I have used Solid works for many years. My questions is how to set the singal arrow when dimension a diameter. I figred out how to chage one dimension at a time but I want to set my defaults. Thanks in advance.
Re: newbe to NX setting defaults
In my opinion the best way to do it is creating your own (company) Drafting Standard in the Customer Defaults
Use Save As Dialog to create a new Standard
Afterwards it is possible to store this informtion in your Template-File for A0-A4...
Now "Load from Settings Source" based on the Customer Default.
Save your template...
If are not fimliar how templates are defined and were they come from and how to create/release them:
Click Here (NX Documetation)
Greetings,
Andre
