nx commnad promote body
what is the use of promote body....give an practicle example for this...
thanks in advance
Re: nx commnad promote body
We used for a casting model. The main (unmachined/rough model) is the master model and all the machining operations +hole drilling are shown in the promoted body. This way you can have two seperate drawings (one solely for Rough casting model) Second for the finished  (machined) model.
Best Regards
Kapil
