nx work slow with complex faces
That can be done to work with complex faces, in other softwares is much faster the fact of cutting or moving, thanx.
example:
https://mega.nz/#!s9UG3RRR!j72SwPHK5S3b2QZLclSm8T93CaiM1fihajMalPeoU00
Re: nx work slow with complex faces
I do not know what CAD you are talking about, I tried to open the file with SW, SE and Inventor, in all three cases the software crashed.
Honored Contributor
Honored Contributor
Elliminate the textured face.  Is it needed, or just for cosmetic reasons?
-Dave
i need work with this kind of textured faces
is a nx11 file
Make the faceting coarser in Visualization Preferences > Faceting. Experiment to find values that work the best. Of course, this will reduce the visual quality of the bump surface, but at least you can work with the model. Then save visualization templates with the settings you've created so you can quickly switch settings later.
Can you add the texture not at the end of the design fases?
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
I can add them at any time usually leave for the end because they are part of the finish, the problem is in the mismanagement of nx with complex surfaces.
section.pngHere I am mixing with convergent but these limited functionality.
