nx10 trim and extend
PLM World Member Creator PLM World Member Creator
i want to extend a surface by.200 on each edge trim and extend use to have a by distance in v10 its gone
Re: nx10 trim and extend
That functionality was moved to the "extend sheet" command.
THANKS I FOUND THAT OUT ABOUT 20 MINUTES AFTER I POSTED THIS.  I HAD A BRAIN FART
