nx11 pmi section
Hi, the PMI command "Section View" is changed in NX11 and does not have the option for sketching the section line anymore. It seems like it is only possible to make section with one/two planes or box option.
How can I make a stepped section like in NX10?  I attach some images for more details, thank you
5 REPLIES 5
Re: nx11 pmi section
Yes i also could not find the sketch option inPMI anymore however it seems you can still access the leagcy PMI SECTION command https://docs.plm.automation.siemens.com/tdoc/nx/11/nx_help/#uid:xid1128417:index_pmi:xid463892:id964...Smiley TongueSmiley Tongue  .
Kapil
thank you!
unfortunately it seems it has been definitely removed in NX11.01.11: I look for it with command finder and can't find it
Hi @Laurus,
Refer the following link from GTAC, you will be able locate and use the 'Section View(Legacy)' command.
Ability to create stepped section in NX 11.0 PMI Section View is not available.
Thank you very much Ganesh,
I had bypassed the problem by loading my NX10 role...No way to prevent us from using it Smiley Wink
