pack non-timestamp geometries?
"Non-timestamp Geometry" node in Part Navigator is a great addition of NX 11.0.2.
I noticed that some composite geometry can be unpacked into single geometries. I wonder whether it is possible to pack single geometries, e.g. those lines shown, into a composite geometry? Thanks!
6 REPLIES 6
Re: pack non-timestamp geometries?
would placing them in an object Group do what you are looking for?
Steve V
Hi, @StevenVickers
Yes, so far object Group is ok.
Object "Group" gives a list of selected geometries, both feature and featureless. "Non-timestamp Geometry" gives a COMPLETE list of and could be a good place to manage featureless geometries, but seems to be too early to be used as a serious organizing tool.
Thanks for your reply!
If I understand your picture correctly, I think that if you assign the same name to the objects, you will be able to pack them. If they each have a different name then you won't.
If individual names are not critical, you could select them all, right click on properties and then assign a new name or delete the existing names by using the (X) icon. Either way, you will be able to pack them.
Abe
Hi @Abeinjapan,
I follow your method, changing a series of lines with the name "LINE9" to "LINE10", and getting a series of single "LINE10". Changing to the same name in properties seems to fail to pack them together. Thanks!
@surfactant I'm not sure why you can't get it to work. Please look at the video below:
(view in My Videos)
Abe
Hi @Abeinjapan
I see why I failed. I should have gone a step further. Thank you!
