problem witht deleting sheets in Draft
Hi everyone !
I can not delete sheet in NX draft. When I try to do it some error appear (pls check attachment):
"Internal error: Access to memory  violation"- it is my translation from polish
Re: problem witht deleting sheets in Draft
Have you tried a Part Cleanup?  If not, make sure you check the option for "Clean Drafting Objects".
If you continue to get the error, please consider contacting GTAC.
Regards, Ben
where is this option: "clean rafting object"?
best regards
Here it is...
Best Regards
Kapil
thank you!
