"Save As" button is not available
On some drawings, the "Save As" function is not available.  Does anyone know why this might happen and how to fix it?  I am just trying to create a new item revision.
I am using NX 10 and Teamcenter 10.  Thanks.
Re: "Save As" button is not available
In a managed mode, Teamcenter, the drawing is tied to the model. So to revise the drawing you need to revise the model and the drawing comes along for free. Depending on your implementation that is what I think is happening as that is how my NX/TC installation works.
Scott
"Save as" won't be available if you are in a specification file; you'll need to switch to the master file to do the save-as.
Thanks.
Thanks.
