remember "Top Selection Priority"?
Q1: Every time I set "Top Selection Priority - Face". After restarting NX would return to the defaut "Top Selection Priority - Feature". Is it possible to make NX remember "Top Selection Priority - Face"?
Q2: When click a sketch, the whole sketch would be selected. Is it possible to make single element in the sketch as the selection priority?
Thanks!
Re: remember "Top Selection Priority"?
Hi @surfactant,
Currently there is no preference or customer default setting available to preset the top selection priority. Users may have different selection priorities depending upon the context of work. You have to use the OOTB shortcut keys to set the current top selection priority quickly.
Quickpick dialog can be used to select single object of a inactive sketch or selection filter.
Ganesh
Hi @GaneshKadole   Thanks for the quick answer!
