removing part number from modeling window view
How do I make it so the part number of a component does not hover over the components in an assembly? It gets cluttered with large assemblies. NX9.0.
5 REPLIES 5
Re: removing part number from modeling window view
Hi AICLE,
You can hide it by Show and Hide command,
View >Show and Hide (short cut is Ctrl+W).
But my concern about note type so
Can you tell me exactly Note type? Is it PMI note ,Simply note or anything else so we can give You exact answer for this?
RRG
Menu -> preferences -> visualization -> names/borders -> set the show object names option to "off".
Perfect, thank you!
Hi Cowski1
Thanks for your reply , I was also not aware of this Show Object Names Prefraences.
RRG
Same can be set under the Customer Defaults settings.
Gateway > Visualization > Names/Borders tabcd.PNG
