render
hello, I am having some problems with render (NX10); I notice great difference between the Raytraced dynamic and the stationary real time preview; I set material, colors and everything, then if I change settings in the Scene Editor to improve the result (global illunination for instance), the colors become totally different, between the two types of preview, and the static image generated is not at all similar to what I am visualizing in the graphic windows. This makes it very hard to decide the settings... I attach an image
Thanks to anybody who can give me good hints!
Re: render
have you messed around with your lights.  Make sure they are turned on for the ray traced studio rendering.  It is in that same scene box as a tab.  Just a thought.  Thanks
