12-10-2017 10:55 AM - edited 12-10-2017 10:58 AM
Very often in building a spline, alignment of the tangent direction gives the undesired direction. Is there any way to reverse it readily?
Thanks!
Solved! Go to Solution.
12-10-2017 11:46 AM
Ciao,
expand the Constraint group, select the point from the list then reverse tangent.
Ciao
12-10-2017 11:56 AM
Hi @Cesare, learnt so much from you. Thank you!
