severe bug at modifying and leaving a sketch
Dear community,
I experienced a really annoying bug a few times already.
Does anybody of you know this bug as well?
What is the reason for that behavior?
I work with assemblies, components and links. I want to modify a sketch, e.g. a dimension. Then I want to leave the sketch by pressing the "Finish Sketch" button. In this moment I just see that my dimension modified turns back to its old value and I am still in the sketch.
I have to press "Finish Sketch" a few times to make NG leave the sketch. My Dimension has still the old value.
I really have to leave NG completely, closing all my parts and restatring everything again,
After that I can modify my sketch and also "Finish Sketch" button works properly.
Many thanks for your help.
NX 10.0.3.5
NX Phase 5
NX Patch NX 10.0.3.5 MP10, 11Oct16
Re: severe bug at modifying and leaving a sketch
Sounds like something that should be reported to GTAC (directly or thru your reseller).
Next time it happens, save a copy of your syslog (File -> Help -> Log file)
You might also try running "part cleanup" (File -> Utilities -> part cleanup)
