sketch reference curve disappears
I was playing around inside NX 11 sketcher and noticed that when I make a sketch curve reference and exit the sketcher the curve disappears. It does appear when I edit the sketch.
Is this the new normal? I was hoping to use the curve as a vector.
Re: sketch reference curve disappears
That's the way it has always worked.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
It's possible to turn off via customer default. Please refer to the what's new. Press F1 on nx opened and your browser will be directed to the Siemens plm nx online help. There look at the what's new.
Thank you...
Using NX11 and NX1847
RuleDesigner PDM
hello Ryan,
As far as i guess NX-11 is not built like that ,because i never faced issue when i worked with NX-11.
please have a check wether the Refernced sketch is being moved to some layer .
kindly have a look at with the attached image.
thanks
Yogesh B
